Marc Rochkind
- Aug 26, 2000
For receivers that use those spring clips with the holes in them, is it better to use bare wire or pin connectors?
With a binding post one would normally not use bare wire, but I'd be concerned about whether with spring clips there's enough pressure and enough surface area to give a proper connection if pins are used. Perhaps in this case bare wire is a better choice?
