receiver's fuse
Discussion in 'AV Receivers' started by al lout, Jan 10, 2005.
  1. al lout
    al lout Stunt Coordinator
    May 6, 2004
    164
    Hi all,
    I have a question regarding receiver's fuse. My yamaha htr 5560 died 4 months ago. Now that I want to fix it up, first w/ the fuse. I took the fuse off my receiver, it shows 8amp 125v. I went to radioshack and couple other electronics stores. They don't have 8 amp. I remembered that 1 store carries a 6.3amp and 10amp fuse. Can I replace it w/ the 10amp fuse instead of the 8amp from Yamaha? Thanks in advanced.
    Al,
  2. Peter Fallon
    Peter Fallon Extra
    Jan 11, 2003
    18
    Radio Shack carries 8A 250V fuses, in both Fast Acting(RS Catalog #: 270-1014) and Slow Blow (RS Catalog #: 270-1030) forms. Check the blown fuse to make sure you pick the right style.
    Don't replace it with a 10A fuse, that would defeat the purpose of having a fuse in the first place.
  3. al lout
    May 6, 2004
    164
    I failed to mention that the fuse size is 5X20mm. I've checked a few Radioshack stores but none carry it. Anybody know where I can get the fuse 8amp 125V or 250V 5x20mm slow blow. I'm in southern california (Los Angeles). Thanks.
  4. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
  5. al lout
    May 6, 2004
    164
    Thanks for the info. I went out locally I bought a new fuse. Unfortunately, after put the new fuse in my receiver still show no sign of life... Any ideas other than bringing it to the shop. As I don't want to spent over 100 dollars to have it fix. Thanks.
