Receiver with 5 channels of amplification but 7 pre-outs
Discussion in 'Archived Threads 2001-2004' started by Fernando.F, Nov 21, 2002.
  1. Fernando.F
    Fernando.F Auditioning
    Nov 5, 2002
    5
    Are there any receivers with 5 channels of amplification with 7 preouts and supporting all the formats? (6.1 DTS EX DD ES?)I want to use my two channel amplifier to drive the left/right fronts. Thanks for any info.
  2. Craig Ball
    Craig Ball Second Unit
    Oct 6, 2000
    278
    Harmon Kardon
  3. Craig Ball
    Oct 6, 2000
    278
    Harman Kardon
  4. Fernando.F
    Nov 5, 2002
    5
    Can you please tell me which HK? And the existing 5 channels can be reassigned to the Left/right side surrounds and the left/right back surrounds? Thanks for the help.
  5. Chris Purvis
    Chris Purvis Stunt Coordinator
    Dec 11, 2001
    151
    the H/K 520 is the least expensive harmon kardon which has reassignable amp channels. It does not decode DD EX though. It does decode DD 5.1, dts 5.1 and dts 6.1.
    The newer h/k's which do decode DD EX are 7 channel receivers.
  6. Craig Ball
    Oct 6, 2000
    278
  7. Greg_W
    Greg_W Stunt Coordinator
    Jul 6, 2001
    54
    The Rotel 1055 receiver also has this with the amps in the receiver reassignable to the center backs. MSRP $1200 US
  8. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
    NAD 752 (MSRP A$1600)
  9. Fernando.F
    Nov 5, 2002
    5
    Thanks for your input.
  10. Dave Bertrand
    Dave Bertrand Auditioning
    Nov 25, 2001
    13
    Actually, the only Harman Kardon receiver that matches your request is the AVR-8000. The others either have 7 amp channels or lack 7-channel pre-outs.
  11. Wyatt_Y
    Wyatt_Y Stunt Coordinator
    Jan 22, 2002
    74
    The HK 320 and 520 have 5 channel amps with 7.1 processing. Both the 320 and 520 have 7.1 preouts (I just bought a 320 which I'm using as a DPL-II and Logic-7 processor). I believe the earlier post is correct in that the 520 has reassignable amps so that you can use an external amp for front L & R. The 320 amps are fixed and you add an external amp for the surround back channels.
    Wyatt
  12. Jeff Gre
    Jeff Gre Auditioning
    Oct 9, 2002
    7
    NAD T752 @ $899 MSRP
