Jeff Ery
- Oct 24, 2002
Good Two channel music is MUCH more demanding then good ht sound....sometimes a system will sound incredible with ht (ala processing, decoding, channel seperation etc..) but could possible sound bright, shrill or the like for two channel music..same thing with 5 channel amps versues two channel amps, some are made with ht in mind and some with music in mind
END QUOTE.....
And some movie soundtracks are recorded to much higher standards and are much more demanding than cd's.....if you don't think that you can determine the quality of a good pre-amp section/amplifier by listening to a movie sound track ,then fine , I would contend that you either aren't using the right demo soundtracks or you have some other deficciancy....I listen to MUSIC FAR MORE OFTEN than I watch movies but when I evaluate the quality of performance of gear, movies are no less an important part of that evaluation.....
As for the signal paths of the pre-amp section of a rcvr and how much quality they put into these parts (both driving the internal amps as well as any other components in the chain to the pre-out) and the "noises", "sonic signature" and "build quality" vs. a pre-pro, I wish we could have one of the guys from Tag or Lex post their feelings .....
I certainly believe that there are ,undoubtedly , some low-end pre-pro's that use no better parts than that of some rcvrs...So, I would stay away from them if you can't hear a differance...try something a little better made.....
END QUOTE.....
