Paul Clarke
- Jan 29, 2002
Here's the setup:
(Only Stereo tested)
H/K 510 in main system with 2 Wharfedale Emerald 97 towers
H/K 310 as pre/pro with Parasound 855A and 2 Wharfedale 97's
Channel levels were at 0 on both H/K's and volumes at -25
Gain was maxed on the amp
Test tone at 1kHz showed a 5+dB increase for the 310/amp
Other test tones also yielded anywhere from 2.5-4dB increase for the duo.
Same passage music content yielded 2-3dB increase on avg.
Question?...Can I expect the 310 as a pre/pro to approximate
the 510? I just didn't feel like tearing everything down so I could add in the 855 to the 510 which is my ultimate aim. Both H/K's have the same innards and feature set differs only in HDCD decoding (which wasn't utilized in testing) and extra watts for the 510. Since the power rating of the 510 and 855 is very similar, I wanted to see if there would be a significant difference. Considering the 855 is brand new out of the box with no break-in, I found the sound change to be quite apparent and certainly the Spl's bear out the power difference.
Any opinions...insights? TIA
