Receiver Upgrade - Kenwood 405 to 507 or 509?
Discussion in 'Archived Threads 2001-2004' started by Martin Fontaine, Aug 19, 2001.
  1. Martin Fontaine
    Martin Fontaine Supporting Actor
    Aug 15, 2001
    626
    About a year ago, I bought the Kenwood HTB-353 which contains the Kenwood VR-405 and some speakers to go with it, they may not be the best speakers but for my needs (Apartment Dweller), they do the job perfectly.
    I am thinking about changing the receiver for the following reasons:
    - Now that more and more DVDs have DTS on them, the lack of DTS support on my receiver is starting to annoy me.
    - I use my PC to do some video capture for Music Videos, some scenes from DVDs I like to cap and send to people and stuff like that. For now, I am using my TV's Monitor-Out (Composite RCA-Jack) to feed the picture from the DVD or Digital-Cable into the PC. I wanna use S-Video, so S-Video Switching would be handy.
    - 6ch Audio Inputs might be useful to me if DVD Audio gets more popular and that many disks of my kind of music (Female singers/songwriters) gets released, I would go into that and don't want to change my receiver again. And to do some 4-Point Surround tests with my SBLive...
    - DPL2 sounds like a great improvement for Stereo Music or Movies/TV Shows.
    To what I can see from Kenwood's web site, the only difference between the 507 and 509 is the Component Switching which I don't think I will need, so far the only device I have that has Component Video is my DVD Player and my TV doesn't have Component In (Currently using S-Video) so I guess it's pretty much useless now. Any other diffs between the 507 and 509 that may justify the 100$(Cdn) Price Diff.?
    And also the most important thing is, will my current speakers work with it? I know they can only go to 80wpc and the 507/509 are 100wpc receivers, even if I don't crank it to the max (Like I said, I'm an Apartment Dweller) are there any risks that I blow my speakers?
    And again, with those speakers, will I really tell the diff between AC3 and DTS? I mean, sound clarity-wise, not bass-wise. Considering I can tell the diff between 384k and 448k AC3 and between AC3 and uncompressed PCM. I might upgrade the speakers eventually but for now, they'll do just fine (I hope).
    I hope someone can help me make a good decision.
  2. Doug_H
    Doug_H Supporting Actor
    Mar 21, 2000
    586
    The 509 had upgraded amps and a few other goodies that make it a better receiver. I would go that way. If you can drop just a little more money the 510 is THX and offers some unbelievable performance for the money.
    The Mischievous Rogue Strikes Again! The Humble Hanson Theater
  3. JohnRyan
    JohnRyan Stunt Coordinator
    Mar 15, 2001
    94
    I was also having trouble deciding as to which model to buy, 507 or 509. I decided I could live without the RF remote and the fact that my TV does not have components in/out so that would have been useless. SO I decided to go with the 507. I went ahead and bout the HTB-504 which included the speakers and sub. It sounds great for now until I upgrade the speakers to the JBL-NSP1 in a few years.
    This receiver is pretty cool.
    Good luck.
    "I've got to get me one of them DVD rewinders!"
  4. Eugene Hsieh
    Eugene Hsieh Supporting Actor
    Jun 30, 1997
    550
    Tell me how it is. I'm still considering the 510, vs. the Sovereign 5080/5090 or Denon 2802/3802.
    Don't worry about it. You'll know if you've cranked it too loud. Too many people actually underpower their speakers.
    By the way, Don't for a second believe their numbers are comparable to most of the higher end ones. I wonder if their 0.7% THD 100 W 8 Ohm spec is partially because they're stressing out their amps more to get the bigger Wattage number. Even their higher end 5090 (which lists for CAD$3000 at Crutchfield) gets "only" 80 W at 6 Ohm, but with 0.06% THD.
    Eugene Hsieh, VisorCentral FAQ Editor
    1000 km on a tank of gas??? Check out the Prius and drive the future now!
    [Edited last by Eugene Hsieh on August 21, 2001 at 03:48 PM]
  5. Eugene Hsieh
    Jun 30, 1997
    550
    I got a Kenwood VR-510 for $552 Canadian today. That's about US$356. I was strongly considering the Sovereign 5090, but given I might have had to spend CAD$1700 for it, I just couldn't pass up the deal.
