Receiver Switched Outlet (1 Viewer)
Ken Custodio
Is it ok to plug a lamp into the outlet on the back of a receiver?
(Woohoo, this is my 100th post on this forum. So please answer :) )
Bill_Weinreich
The outlet should have a rating on it. Check the wattage to make sure it isnt too much. It shouldn't be a problem.
Bill
Todd Hochard
What type of lamp? Fluorescent lamps can add a bit of noise on the AC line, which would pollute your AC input to the receiver.
Listen closely to see if you can hear any hum/noise/sonic degradation. If not, enjoy. And, I wouldn't go above 60W, generally speaking.
Todd
