I have an old Denon AVR3000. It doesn't have sub signal level control. Is there something out there I can buy that can boost the signal to the sub amp? Thanks!
Would your sub happen to have dual inputs like on my Cerwin Vega LW-15?
It has a "left" and "right" input...it sums the two input into one and signal going in is doubled.
My receiver only has a single Sub Pre Out. I use a Y-adapter to turn my one input into two. I had almost NO output out of that sub until I got the Y adapter. It was like night and day.
Hi Mike! Maybe I didn't explain correctly. The sub is passive. The receivers mono out is not sending a strong signal to the sub-amp. Can't boost it. I believe your answer is refereing to a powered sub.
