Receiver shutting off
Discussion in 'AV Receivers' started by Junie, Jun 7, 2005.
  1. Junie
    Junie Agent
    Jan 17, 2002
    45
    I recently add a Rotel 1075 to my system and now use the Marantz 5200 I have as the prepro. When I turn on the system the Marantz will play for a couple of minutes and then will shut down. I thought it was because of heat at first, but the same thing happened befor it could heat up any thoughts?
  2. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    If the Marantz will play without a shutdown in a stand alone mode, then it's either the Rotel or a cabling problem.
    Mort (who'd give his best bet on speaker wires touching something somewhere)
  3. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    You don't have the power for the Rotel amp running off one of the outlets on the back of the Marantz, do you??? If so then move the amp power to a wall outlet and try again.
  4. Junie
    Junie Agent
    Jan 17, 2002
    45
    I have the Rotel plugged into its own outlet. when mention speaker wires touching something you mean on the back of the rotel right?
  5. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    How is the Marantz wired to the Rotel. What outputs on the Marantz are you using, are the cables in good condition (visually)??? I'm beginning to think you need to do what the first response said to do and that's to isolate the Marantz and see if the problem still exists in that condition.
  6. Junie
    Junie Agent
    Jan 17, 2002
    45
    I have the Marantz wired to the Rotel through the preouts only. I will isolate the Marantz and see what happens. However it just came to mind that I had a couple of wires (speakers) that did not have plugs on them I will the plugs and put them in place. the connects between the componets are new with no visable damage or defects.
  7. Mort Corey
    Nov 21, 2003
    981
    I'll wager that you find a couple of speaker wire strands touching (either at the receiver or speaker...or both) and causing a short. It doesn't take much and that would explain a non-heat, near instant shutdown.
    Good hunting.
    Mort
