Receiver shutting down!
Discussion in 'AV Receivers' started by Randy Lane, Nov 7, 2005.
  1. Randy Lane
    Randy Lane Auditioning
    Jul 11, 2005
    2
    I've had a Yamaha 502 receiver for a little over a year (bought it used). DVD player, cassette deck, VCR, and 4 speakers connected. Speakers are connected with banana plugs. Up until last week, I never had a problem. But my receiver has been turning itself off whenever I turn the volume up. I can only turn it up just slightly above the lowest setting before it does this. This happened with an old Denon receiver I had, but only after using it for 10 years. The Denon never powered back up once it shut down. But the Yamaha comes back on when I hit the power switch.
    Is this the result of a power drain, and if so, why has this just started happening?
    Thanks!
  2. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    Make certain your receiver has plenty of breathing room, as heat can cause this.
    Make certain you don't have a blown tweeter or midrange, as that short can cause it.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    If it is not a heat issue which is pretty common on this one, it is usually a wire problem, check and maybe even re-do all your conenctions, next most common is a blown driver somewhere in one of the speakers.
    Next most common sadly enough is the AVR is malfunctioning.
