Receiver Question
Discussion in 'AV Receivers' started by DavidShlapak, Oct 5, 2005.
  1. DavidShlapak
    DavidShlapak Auditioning
    Oct 5, 2005
    4
    Hey, all. Almost certainly at least a near-FAQ, but...
    I'm looking for a 7.1 receiver in the $1-2K price range. My current system is built around a Rotel RSX-965, which I like. So I'm considering the RSX-1067 for my new setup, but it's at the high end of my price range so I'm wondering if there's something a little...er, more modest...that might do the trick. Is there any consensus--or even just a couple of popular recommendations--out there?
    One unit that I've seen that looks promising is the Yamaha RX-V2600; I'd love to hear about any experiences with that.
    Thanks in advance for any advice.
    Cheers.
    --- das
    PS --- Sorry, meant to also say that this is mainly going to be used for movies & TV; maybe 90/10 between that and music.
  2. Chris Rock
    Chris Rock Supporting Actor
    Jan 10, 2001
    710
    Maybe the Denon 3806?
    It compares pretty evenly with the Yamaha you mentioned (I'm also looking at that one).
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I dunno, what does a Denon 4806 go for? Seems you may be able to find one for around that.
    H/K has their 7000 series. I mean, you can get flagship/very near flagship level for $2000 easy.
    I sure have been exceedingly pleased with my Denon 4802 for a long time now. Flagship level AVR's are pretty impressive and special in my opinion.
    I don't see how you could go wrong with these level AVR's from any of the main stream guys really.
    Let us know what you decide though for sure.
  4. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    Well John, the 4806 lists for $3,500 but perhaps with your connections you can help him find one for between $1K-$2K.
    The HK 7300 is readily available for $1,300 delivered, but the fan noise problem........
    The Denon 3806 is probably not a bad suggestion.
