Receiver Problem
Discussion in 'Archived Threads 2001-2004' started by Shelby_P, Jul 29, 2002.
  1. Shelby_P
    Shelby_P Auditioning
    Jul 29, 2002
    I am new to home audio and have a small problem with a very simple set-up. Basically, I have 4 speakers hooked up to my Yamaha receiver, 2 plugged in for 'front', 1 for 'center' and 2 for 'rear.' My problem is, when I test the channels (a feature on the receiver where the channel is displayed and static comes from the speaker) the rear speakers make no sound when 'Rear' gets tested. The front and center work fine. I know the wire and speakers work fine from testing them on the 'front' input. Any suggestions??
  2. Angelo_Petralba
    Angelo_Petralba Second Unit
    Jan 22, 2002
    366
    Welcome Shelby-
    The only thing I can think of is the speaker connections in the back of the receiver is incorrect. Make sure they are connected to the SURROUND connectors and not the Speaker B.
    Also, make sure the Connections are secure on both the receiver and speaker ends.
    Good Luck
    Angelo
  3. Gerard Martin
    Gerard Martin Second Unit
    May 22, 2000
    366
    Check your receivers setup menu and make
    sure the rear speakers are NOT set to none.
