Receiver or Pre amp/amp
Discussion in 'Archived Threads 2001-2004' started by Shawn.G, Dec 19, 2002.
  1. Shawn.G
    Shawn.G Second Unit
    Oct 28, 2002
    265
    I am thinking about getting a used receiver. Any receiver will be better built than mine, so I figured get more watts to each channel. I am thinking of 2 channel with a sub. Or should I go seperates? Which would be best for a limited budget?
  2. Shawn.G
    Shawn.G Second Unit
    Oct 28, 2002
    265
    I think I will get a receiver now with preouts to sub,L,R,C. Then get an amp for the mains later. What is a good receiver I can get for 150 on ebay or here? Thanks.
  3. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Unless there are some really exceptional deals out there (occasionally there are) I would not recommend separates to anyone describing themself as "on a limited budget". If your budget is limited I would concentrate on finding last year's models on closeout. Check the gotapex link at the top of some of the forum pages.
