Chris Svencer
- Mar 4, 2002
I will be buying a receiver in the next couple of weeks and have been looking at the Denon 3802 and a couple others. One feature that I really like about the denon is that all of the settings you put on during an input stay with that input. Example- If you really like the bass up and the center channel a little louder while watching movies but prefer the bass not so dramatic while listening to the tuner it will remember both settings. It makes it so you don't have to change everything when you change what you are listening to. So I guess my question is do any other receivers do this or something similar? Or is this just a little Denon perk??? Thanks.
Svence
Svence
