Ryan.S.
Grip
- Dec 7, 2003
Well I'm trying to pick a receiver. I don't wanna spend too much on it... but I want something nice.
So far both the Onkyo TX-SR501 and the Sony STR-DE695 look pretty good and seem like they have everything I want.
So which one would you guys recommend? Or any other receivers that you think would be a better choice. I'd like to spend as close to $300 as possible for the receiver... but if there is a huge difference on something a little bit more expensive I might go for that.
I was also looking at the specs on the Kennwood receivers... The wattage is a lot higher and they come with a lot more stuff for a lot less money... now I'm sure there is something that is sacrificed... so what do you guys know about these?
