Receiver Help!!!
Discussion in 'AV Receivers' started by ArthurJ, Dec 3, 2003.
  1. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    I want to buy a receiver for now, and in about 3-4 months I will be adding a 5ch. amp. My problem is this; if I know I will be bypassing the amplifier section should I go for the receiver with the better features and forget about amp quality? I'm looking at the Denon AVR-3803S and the Harman Kardon AVR 630!
    http://www.crutchfield.com/S-ODvLyLU...p?i=033AV3803S
  2. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    Why not get that Denon 3803 deal from 6th Avenue for $650?
    I'm not sure if it's still going on but it should be. That should save you a few bills. Oh yeah, and what would you be running w/ this receiver? If your speakers aren't too power hungry, that 3803 should be fine.
  3. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    it's the 3802 that is $650!
  4. Ernest Yee
    Jun 6, 2003
    539
    NO - just call and ask about the 3803 - essentially they ran out of the 3802s and were replacing them w/ 3803s. It's a pretty wide-known deal that's out right now.
  5. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
    Really? wow, thanks for letting me know, I better jump on that fast!
  6. John S
    John S Producer
    Nov 4, 2003
    5,460
    Yep, that 3803 is a bad mammajamma on the pre pro section, and quite respectable on the power amp section.
    The $640 deal is sweet, one of the better deals I have ever seen really.
    I'll bet it runs reference levels just fine, even in a fairly large room, with relatively inefficient speakers.
    I have the 4802 and it has quite a bit of headroom at reference levels in my 30x20 room with 10' cielings.
  7. Ernest Yee
    Jun 6, 2003
    539
    Enjoy! [​IMG]
