receiver/dvd/dd decoder hookup question
Discussion in 'Archived Threads 2001-2004' started by Christ Reynolds, Aug 3, 2002.
  1. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    hopfully this is the correct forum for this, if it isnt, my apologies. i recently purchased a denon avd-2000 for DD decoding for laserdiscs, as it has an ac3-rf in. as it turns out, i cant use the decoder for laserdisc DD because my ld player had no ac3-rf out. kinda sucks when you realize you have no idea what youre talking about
    . anyway, on to my real question. i have my dvd player hooked up to my receiver through an optical cable. what would the benefits be if i used the denon unit to do my dolby digital processing, with the analog input/outputs? i believe my dvd player has analog outs, and i believe my receiver has analog ins. heres the equipment involved-
    receiver - sony str-de945
    dvd player - sony dvp-c660
    decoder - denon avd-2000
    thanks in advance
    CJ
  2. Christ Reynolds
    May 6, 2002
    3,597
    CJ
    looked at the back of my dvd player, and it doesnt appear to have analog out. i think the heat is getting to me. could i run an optical cable from my dvd player to the decoder, and from the decoder to the receiver use the analog ins/outs? like use the denon to decode the dolby digital, and let the receiver decode dts? basically, is there any way i can benefit from the denon unit before i get a ld player with ac-3 rf out? i need help, thanks
    CJ
  3. Kevin Alexander
    Kevin Alexander Screenwriter
    Apr 17, 1999
    1,357
    It appears as if the Denon really serves no purpose. You alreay hade DD/DTS built into your receiver, so why not let the Sony handle both the DD and DTS processing? I see you gaining nothing by spliting the decoding duties between the two.
  4. Christ Reynolds
    May 6, 2002
    3,597
    CJ
    ok then, i didnt know if the denon was a better decoder, i dont suppose it really matters what handles the bitstream. looks like the denon will have to remain unused for a little while, thanks
    CJ
