Receiver Component Hook up?
Discussion in 'Beginners, General Questions' started by Omard., Oct 10, 2003.
  1. Omard.
    Omard. Stunt Coordinator
    Feb 28, 2003
    200
    What is the advantage of hooking up your video components thru a receiver?
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Some people like to control everything through their receiver.
    A big advantage is if your TV is short of component inputs (for example you have only two sets of component inputs and have a DVD player, an HD satellite receiver and an X-Box) Running two or more of these into a receiver and then one output to your TV allows everything to be connected without buying a switch box.
    If it were me and I would connect directly unless short of inputs.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    It’s also more convenient: You get both audio and video happening on the system with one button on the remote. Connect video signals directly to the TV and you have to switch audio and video separately each time you change components.
    Wayne A. Pflughaupt
  4. Omard.
    Feb 28, 2003
    200
    So you would have the receiver hooked up to the tv thru one cable and then all the others components whould be connected to the receiver. So you would always keep the tv on video 1 and just switch the receiver from dvd to cable? Is there any loss of video quality?
  5. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
  6. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
