Receiver and DVD/CD/SACD speaker setup coexistence
Discussion in 'Beginners, General Questions' started by Jack Leslie, Mar 3, 2005.
  1. Jack Leslie
    Jack Leslie Auditioning
    Dec 7, 2002
    6
    I have not found an answer for this, but really have not thought of it before.
    Both my receiver (HK 8000) and player (999ES) have the capability in the setup menus for speaker distance delay and dB adjustment. Neither manual states if both should be set up, or if say the receiver has the delay and balance capability, then the player should be set to default.
  2. Brian Fellmeth
    Jul 30, 2000
    789
    Set up both because only one is used at a time. The box that is doing the D to A converting uses the settings. For SACD for example that would be the player and for DVD that would be the receiver.
  3. Jack Leslie
    Dec 7, 2002
    6
    The player does have settings for both DVD/CD and SACD. So it the DVD/CD player settings are say for 9ft distance, would that not be cumulative with the receivers 9ft distance settings as well equaling 18ft?
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Jack.. When feeding the AVR a digital signal, nothing you set in the DVD player is going to effect it.
    The settings apply when you use the 6 analog cables from the player to the 6 analog inputs on the AVR. Pretty darn sure on this one.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    What John said. Speaker settings in the player are ignored when using a digital connection. I would recommend this for DVDs and probably redbook CDs also, because most receivers have better bass management.
    For SACD, you have no choice but to use the analog connection (unless the player and receiver are firewire capable). So your player's settings are used.
    In either case, you will never be using the settings of both units.
  6. Jack Leslie
    Dec 7, 2002
    6
    Thanks for the answers guys.
