Receiver amp or powered sub?
Discussion in 'Archived Threads 2001-2004' started by JoshuaIan, Mar 14, 2003.
  1. JoshuaIan
    JoshuaIan Auditioning
    Jan 14, 2003
    5
    my Technics SA-EX900 has a built in 100W sub amp.. the back of the unit also sports an output for a powered sub... would using my receivers amp or a powered sub sound better?
  2. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
    I would suspect that the Technics amp is not the best quality. Also is the 100 watts max or RMS. Also what is you budget for a sub? You also may have a harder time finding a passive sub rather then an active one.
  3. Carl Johnson
    Carl Johnson Cinematographer
    May 6, 1999
    2,259
    25
    1,610
    Carl III
    YOu'd be better off with a powered sub. The less work your receiver has to do the better.
