received (2) Tumults and a XXX 15 today!!!
Discussion in 'Home Theater Projects' started by Brian-K-Owens, Jul 18, 2003.
  1. Brian-K-Owens
    Brian-K-Owens Stunt Coordinator
    Feb 6, 2003
    194
    I have not inspected the Tumults yet, but when I removed the XXX from the box to check out the new dustcap, the frame was cracked in 2 places!!!!!
    I guess I can join the club of UPS carelessness!!! I think this happened to Brian B too. Must be something UPS has against Brian's. . . .
  2. Tracy_L
    Tracy_L Stunt Coordinator
    Jan 11, 2003
    70
    Hey Brian
    With your luck with speakers, I'd stay out of the casinos....[​IMG]
    Tracy
  3. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    Personally, I think it was the driver getting back at you for delivering 3 boxes weighing 70lbs each the same day[​IMG]
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    my thoughts exactly
    got pics?
  5. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Brian,
    Yep this happened to me too. [​IMG] Luckily all is going good now. I have mine; my customer has both of his.
  6. Mike.D.K
    Mike.D.K Stunt Coordinator
    Dec 5, 2001
    59
    I had to have 5 Blueprint drivers sent to me before I received two that weren't broke. They were shipped Fed Ex ground. I feel your pain.
  7. I have had 2 SV-10s, 2 drivers about the weight ot the brahma 12, 2 1503's (well, one was picked up), and a tumult. So far, everything has been tip top. I guess I am just lucky so far! *knocks on wood*
  8. Brian-K-Owens
    Feb 6, 2003
    194
    On a good note, the Tumults are AWESOME!!!
    Each is in a 2.5 ft^3 sealed enclosure with med-heavy stuffing. I am using a QSC PLX3402 on the pair. I have a BFD, but have not tuned yet. Right now, I have bands 1 and 2 set at 20 Hz and 25 Hz (widest bandwidth) @ 6 dB of boost. Then I have bands 11 and 12 set to filter out a little more of the HF that my LFE output does not get. Even in sealed boxes, they make more than enough bass. I have not metered them yet, but the pair seems to keep up with the single 1803 I had in a 13ft^3 ported enclosure, but the sound is MUCH cleaner.
    Brian
  9. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Haven't received a damaged driver yet. Even my Blueprint 1803 was ok.
