Reccomendations for Wall Mounts for Rear Speakers (1 Viewer)
BrianSmithe
I just need some advice here. I'm going to be moving my CSW Newton M50's to rear speakers so I want to get wall mounts for them. I want something that rotatoes and obviously is able to support my speakers. Idealy if they are available in white/cream color that'd be great. Thanks!
Ted Lee
i can't remember the brand, but both cc and gg used to sell this ball-swivel mount brand that came in this blister-pak. they came in black and white and seemed pretty solid.
they sort of looked like the bose cube mounts.
i think best buy also has some, but not sure.
sorry couldn't be more useful...
kevitra
Do a search on this site or google for 'speaker wall mount' and you will find a lot.
BrianSmithe
I'll do a search, thanks :) I was thinking about in-wall speakers but I dont have the extra $$ to spend on them :frowning:
Jeff Kohn
has anyone ever used these?
http://www.cambridgesoundworks.com/...s/vogel_blk.htm
Those are the reccomended wall mounts for my speakers. Unless anyone has bad things to say, I think i'll get those. 29.99$ a pair
These mounts will put the speaker very close to the wall, so close in fact that you'll have very limited maneuvering space if you need to tilt/angle the speakers much at all. I tried using some of these on my Axiom M3's, which are a little bit bigger than your Newtons, and it just didn't work. I ended up finding some brackets at Lowe's hardware for $20 that were much sturdier and put the speaker a little farther out from the wall.
BrianSmithe
Hmm, good point to think on Jeff, thanks. Jason, I appreciate the offer, but currently I don't have any method of online payment so I don't think it's gonna work out. Thanks for the offer though! I'm going to be mounting the speakers in 2 corners on the wall, for positioning I just want them to angle towards the couch. Do you think I will have a problem angling them with the Vogel brackets? or should I just be safe and go with a differnt brand then?
Jeff Kohn
That's how I mounted mine also. The problem I had was that I couldn't angle the speaker down because the speaker was too tall and it hit the wall before I could angle it down enough. You also might want to check PartsExpress.com I believe they have quite a few brackets in different sizes.
BrianSmithe
ok, I'm not sure if I'll have that problem because my speaker is a bit smalller in height, but still it's a good thing to think about. I appreciate the help Jeff and I'll take a look at Parts Express :)
Craig Woodhall
Brian,
mine look great on the walls, couldn't be happier with them.. just for reference, they were $79.99 CDN..
Craig
sonjabe33
