Robert Silge
- Jan 8, 1999
I was wondering if anyone had any advise on the best way to take apart and rebuild a sonosub. When building mine a stupid math error (should have paid more attention in high school algebra I guess) forced me to stick my ports out the top instead of setting them flush (if I remember I cut them too short).
I was thinking of removing the top and replacing the PVC pipes with longer ones. I doubt there's a good way to remove just the pipes, so my options as I see them are:
Cut the tops off and then add pipe to the inside with a female-female joint. Not sure what this would do to the effectiveness of the port though. May not be the best idea.
Cut the top MDF off and rebuild that part and replace it with a new one.
For both of these I need to remove the top double layer of MDF and the only way I can think to do this is to cut the sonotube with a utility knife and recalculate all my volumes for a slightly smaller tube.
Any better idea?
-Rob
My meager collection:
www.dvdtracker.com/~lazarus.asp
Any better idea?
-Rob
