Reassign Drive Letters in Windows XP?
Discussion in 'Archived Threads 2001-2004' started by Josh Campbell, Feb 22, 2003.
  1. Josh Campbell
    Josh Campbell Stunt Coordinator
    Nov 30, 2001
    60
    Hi, Does anyone know how to reassign drive letters in windows WP? For some reason my two cd ROM drives are labeled D and G. I have 2 hard drives, one of which has two partitions. They are labeled C, E, and F. What i would like it to have all the hard drives in alphabetical order, then the cd-rom drives. Any help on this?
    Josh
  2. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    Start > Control Panel > Administrative Tools > Computer Management > Storage > Disk Management
    Just be careful when you change the drive letters, programs may not function after you do so.
  3. Josh Campbell
    Nov 30, 2001
    60
    Thanks!!! worked like a charm. I had no programs on the drives i need to change, just shn audio files, so it worked with no problems.
    Thanks again!
