Rears & Surronds - should they be able to accept
Discussion in 'Speakers' started by Brad Newton, Jun 23, 2003.
  1. Brad Newton
    Brad Newton Second Unit
    Aug 14, 2001
    382
    as much wattage as the fronts? If your receiver is rated at 110 watts per channel, the fronts @ 120, would rears & surronds be ok being rated at only 50 watts per channel?
  2. JohnnyCorona
    JohnnyCorona Agent
    Jun 16, 2003
    41
    Should be fine, that rating is only for MAX wattage. you just wont be able to turn them up as loud as your fronts.
    Johnny
