Rears on the side?
Discussion in 'Speakers & Subwoofers' started by Joe Pick, Jan 22, 2005.
  1. Joe Pick
    Joe Pick Stunt Coordinator
    Jan 12, 2004
    106
    Hello! Greetings from snowy Michigan.
    My question is on placement of rear surround speakers on the sides or front corners of my room as opposed to behind me. It's tough to get wiring back there with the shape of my room, but would surrounds about 10 feet beyond my fronts be worse than nothing at all? I could also place them in the middle of the room on the sides, but not behind.
    I have PSBs in the front and center now with a NAD A/V receiver.
  2. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    Surrounds can work just as well on the sides as in the rear depending on the speaker and room. If the side is the furthest back you can go, I'd set them up there.
  3. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I agree with Wayne. When seated, you want them about 1 foot behind your head, and about 2 feet above your head.
  4. Gralen
    Gralen Stunt Coordinator
    Aug 8, 2004
    74
    Hi Joe. I have the same problem and my back surround are on the side. just make sure the set up is proper and it will be fine
  5. ScottHH
    ScottHH Stunt Coordinator
    Oct 24, 2002
    174
    Joe,
    Here is what Dolby recommends for speaker setup. The surrounds are really more on the side than behind the seating position anyway. I would think the closer you can get to their recommendations the better, but don't think the effect will be ruined if you have to put the surrounds a little in front of the seating position.
