Rear surround speaker
corona13
michael
I need to cieling mount my rear surround speakers.
They are Klipsch RSV-4 (http://www.klipsch.com/products/details/rsx-4.aspx) , as a result of this, the woofer will be on the top and tweeter on the bottom...basically, upside down.
will this matter much, or should I consider alternative speaker mounting options?
behind the couch stands is an option, although will take a lot of wire as the wire would have to travel through the cieling, down a wall, through the riser than out the riser to the stands...probably 40-50 foot run.
I could also buy in cieling speakers and install where the current set up will go.
or, instead of placing the rear surronds behind the listening position, I could place them on the wall next to the listening position ( this is a 7.2 setup, so I already have the side surronds on the side wall, located between the 1st and 2nd row of seats), and I would have 2 sets speakers on the side wall.
let me hear your thoughts!
thanks!
JohnRice
Bounded In a Nutshell
A Mile High
Go ahead and mount them to the ceiling, "upside down". That is no problem whatsoever. Do not get in-ceiling speakers.
Latest posts
Dynz
