Rear surround speaker type.. (1 Viewer)
rhuber
Ray
Hi everybody,
I am hoping to get some feedback on this question from several folks. In a 5.1surround system, what are some peoples preference as far as rear surrounds? Specifically, do you prefer a dipole/bipole type of speaker of a direct reflecting type? Really curious as to what the masses have to say on this.
Thanks!
Ray
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
First, some clarification on 5.1 sound. There are no 'rear' surrounds with a 5.1 setup. They are side surrounds, designed to be placed to the left/right sides of the listening area. Rear surrounds are for 6.1/7.1 setups.
For side surrounds, I prefer bi-pole type speakers. For rears, direct radiating (although my current setup uses a unique setup - Axiom QS8's for both side and rears). Others will disagree
rhuber
Ray
David,
Your absolutely correct on the speaker placement, guess I should have been more specific. The pre-wiring in my media room is 5.1, as far as total number of speakers, but the surround pre-wires are on the back wall. So I guess the real question is, since I have little choice currently, unless I rip out the existing wiring and wire up the side walls, should I use direct radiating or bipole/dipole speakers on the back wall.
Ray
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
In that case I think I would go with bipole. I believe this type of speaker would allow the sound to be more dispersed. I would seriously look at these - Surround Speakers - AxiomAudio.
I suggest you wait for a few more responses before making your decision. See what others have to say.
rhuber
Ray
Thanks for the input. BTW, I already have the Axioms on my short list.
JoeyT66
