Rear & surronds........how close in watts per channel
Discussion in 'Speakers' started by Brad Newton, Jun 6, 2003.
  1. Brad Newton
    Brad Newton Second Unit
    Aug 14, 2001
    382
    do they need to be to the fronts & center? Or does it make that much difference? Should the be close to the same, half or what?
  2. Jason GT
    Jason GT Second Unit
    Dec 12, 2002
    452
    I wouldn't worry too much about power handling of speakers unless you're at a point where you're thinking of adding serious amplification. Just pick surrounds as you like.
    Like has been said here many times, you're more likely to damage speakers by underpowering them than by overpowering them.
