DaleI
- Jun 5, 2001
I’m going to try another cable, as suggested by the previous link, but I’m not optimistic. Leave it to me to experience an issue that’s stumped even the hometheaterforum community.
4K HDR 24hz isn’t an option. 4K HDR 50hz is the lowest K HDR setting available and it didn’t work.My Apple TV 4K also fails the HDR test on my TV. Try running it in 4K HDR 24hz. I think the problem with my TV is that it wont do HDR at 60hz.
If that works set the display mode to 4K SDR 60hz and make sure that you enable native content display. That way your Apple TV will play movies in 4K HDR 24 hz and play your menus at 4K SDR.
Okay, let’s do this slowly. I was able to select 4K HDR 30Hz and also 24Hz. Which do you suggest? Then what?Go to Format and then click on "other formats". All formats from 4K HDR 60hz to 480p SDR will be available.
this is what I’m looking at, so please use the words here. Native content? Display mode?Okay, let’s do this slowly. I was able to select 4K HDR 30Hz and also 24Hz. Which do you suggest? Then what?
They both were already ON.Select 4K SDR as your format. Under "Match Content" select "Range and Frame Rate".
This is what I have now. I don’t see how that changed anything. I still can’t enable HDR. I’m still at 4:2:0, still at 4K SDR. I was able to change all of these when I went directly to the TV. I thank you, though, for the help.That looks right. Now anything you play will be in it's native format.
Nothing.Didn't you mention that the 4K Bluray works through the receiver? Just to test it, I would take the HDMI cable out of the bluray player and plug it in to the Apple TV and see what happens. It could still be a setting in the receiver for the input you're using for A-TV.
