DaleI
- Jun 5, 2001
I believe Denon and Marantz use the same menu system since they are owned by the same company.
First make sure you are on the Apple TV input.
Use the Denon remote and go to the receiver menu. Then NETWORK->INFORMATION. Here you should see the IP address.
Now on a computer type the ip address into the address bar on Chrome, Explorer, etc. This should bring up a setup menu for the receiver. Go to: VIDEO->OUTPUT SETTINGS
From here you can change the input settings for how the image is sent out. I normally have Video Conversion-On, ip Scaler-HDMI, and Resolution(HDMI)-Auto.
I turn on Video Conversion so the volume shows on screen, if it is turned off you will not see the volume level when you change volume.
Okay. Thanks. So should I change the Apple TV input to go into the receiver again?
When I had it going into the receiver before, I was able to get 5.1 sound.
