DaleI
- Jun 5, 2001
Just discovered that my Denon receiver only has one hdmi output and that’s the ARC output
I’ll take a wild guess that you’re running the audio through the TV, using it to switch your sources. That usually converts all audio to two channel, eliminating 5.1.
Not true. Most new TV's will pass through 5.1 channels including DTS 5.1 through optical. The problem is that it will be PCM and not bitstream which is the only way to get full HD surround.
The bluray player you have should have two outputs on the back. Leave 1 connected to the TV and connect HDMI 2 on the bluray to an input on the receiver. You have the setting correct on the bluray to get full HD surround over bitstream. Make sure that output setting on the bluray is turned on for both outputs. Now try it and see how it sounds.
Some movies do not send a whole lot of sound through the rear speakers. Set the Denon to AUTO for surround mode and then hit DISPLAY to see what the incoming signal is and what speakers are being used.
Brian
That’s fine. You can use it, you just won’t use the ARC, except for internal apps.Just discovered that my Denon receiver only has one hdmi output and that’s the ARC output
I couldn't find anything specific on this TV. The ARC and/or optical typically passes 5.1 for internal apps only. If you know better, please show me where to find this (not saying you are wrong, it just hasn't been the norm for many years).
Also, if you have a 4k receiver, why would you use 2 HDMI connections? I've heard of cases where this messes things up more than helps (BR Player gets confused and starts sending sound based on the TV capability). I use it because I have no choice, but if I had the choice I would not.
And the Disney WOW will send sound to all the speakers. It is not the source that is the problem here.
Regarding NetFlix, or any streaming service, I find that the streaming device definitely makes a difference. My experience is that, in general, smart TVs and most Blu-Ray players (except maybe Oppo) produce lesser image quality, and tend to be twitchy. A good dedicated streaming device, like an Apple TV and, I assume, Roku, just work a lot better in every way. The image quality from my new Apple TV 4K, even with a regular HD TV, is noticeably superior to the Gen 3 Apple TV, which is superior to the other built-in streaming in other components I've tried. Bottom line, if streaming is important, and I suspect that it is or will be very soon to almost everyone, then it's a better use of money to not spend $ for upgraded streaming in the TV, and spend the savings on the dedicated streaming device of your choice.Do most of you launch Netflix from your Smart TV or from your blu ray player? Does it even matter when it comes to picture resolution or 5.1 sound?
Good choice. The Amazon app still has some glitches, but NetFlix should work just fine.I’m buying an Apple TV 4K, so that will settle the matter.
Now that its all working get a test disc, Spears and Munsil 2nd edition and a SPL meter and check all the settings. Enter all your distances in the receiver manually after you measure. After all the amplitude settings are done with the full bandwith pink noise then experiment with the crossover to the sub. Put on familiar bass and sit at your seating position and AB loop some really low bass. Make sure the volume is not so high that you are hearing distortion, but as heavy as you can before it craps out. Then with your remote change the crossover in the receiver around 10hz at a time and see where it sounds the most accurate. I used the Transformers Dark of the Moon bluray begining at chapter 19 upwards. There is a scene where one of the Deceptagons big spaceship gets fd up by 2 little bots, and when it comes down and crashes the signal gets lower and lower and lower. You can go up and down with the crossover point till it is heaviest and still no distortion. Good luck with the system and enjoy!
John I am using an Oppo to stream Net Flix and it wasn't in 5.1Regarding NetFlix, or any streaming service, I find that the streaming device definitely makes a difference. My experience is that, in general, smart TVs and most Blu-Ray players (except maybe Oppo) produce lesser image quality, and tend to be twitchy. A good dedicated streaming device, like an Apple TV and, I assume, Roku, just work a lot better in every way. The image quality from my new Apple TV 4K, even with a regular HD TV, is noticeably superior to the Gen 3 Apple TV, which is superior to the other built-in streaming in other components I've tried. Bottom line, if streaming is important, and I suspect that it is or will be very soon to almost everyone, then it's a better use of money to not spend $ for upgraded streaming in the TV, and spend the savings on the dedicated streaming device of your choice.
NetFlix should be 5.1 on most content.
