Rear speaker position. Which way?
Discussion in 'Archived Threads 2001-2004' started by Brian Olsen, Dec 11, 2002.
  1. Brian Olsen
    Brian Olsen Agent
    Nov 11, 2002
    31
    A friend of mine is running a 5.0 setup and we are very happy with all the components.
    My question is about the rear speakers.
    Which way should they face?
    A) Towards each other
    B) Towards th listeners (Middle of room)
    C) Towards the front of the room (Facing fronts)
  2. Brian Olsen
    Brian Olsen Agent
    Nov 11, 2002
    31
    Bump [​IMG]
  3. AllanN
    AllanN Supporting Actor
    Mar 15, 2002
    950
  4. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    It depends on how you want the sweet spot.
    #1 will give the best effect. But it only works for a very small area between the rear speakers. If you mostly listen alone this is probably the best.
    #2 will give you a bigger sweet spot for multiple listeners. #3 Is robably too much. Pointing towards the center of the room some, but not all the way is generally prefered for a general sweet spot. It is not the most accurate, but usually a good compromise. Also this is prefered for music.
