Jim Rondeau
- Mar 18, 2001
Hi All,
I've been doing some redesign of my home theater and I'd like some advice on rear speaker placement as I'm adding two rear center speakers due to my recent purchase of a Denon 3802. Also I've gone from one row of seating to two. My room is 12' wide by 23' long. The TV and front speakers are on a 12' wall. The first row of seating is at a viewing distance of 10' and the second row is 14' (the single row was originally at 12'). Currently my left and right surrounds are at 14' (even with the second row) starting about 5' up.
I'm wondering if I should leave these speakers where they are or move them forward 4' (even with the first row where I'll be sitting most of the time). 4' is the minimum I can move them forward as one is currently next to a window and moving it 4' would put it on the other side of the window. As far as the two rear center speakers go I do have a shelf in the back of the room I could put these on. This would put them 10' behind the first row and 6' behind the second. Is this to far? They would only be 4 feet up so would not be at the same level as the left and right surround (5'). How important is it that the rear speakers all be at the same level?
I'm open to any suggestions. If need be I can try to suspend the rear centers from the ceiling so they are closer the listening area. If it helps any my main use is 90% movies/10% music. Also, my left/right surrounds are DefTech BPXs and the centers are DefTech BP1Xs. I'm included a pic below too.
Looking at rear of room
Thanks.
Jim
Thanks.
Jim
