Rear speaker advice wanted
Discussion in 'Archived Threads 2001-2004' started by Eric Kahn, Dec 22, 2001.
  1. Eric Kahn
    Eric Kahn Guest
    I am looking for a pair of relativly inexpensive wall mount rear speakers
    I currently use the rear speakers on movies and some TV shows, not for listening to music
    My mains are klipsch Chorus II's and my center is a klipsch KLF C7
    my listening position is against the back wall of the room which means that the rears are going to be mounted on the side walls in the corners up high to clear a door on one side
    Klisch quintets seem to be going for less than 100 for the pair of rear surrounds on Ebay, are they any good or should I buy somthing else?
    Any advice at all??
  2. Eric Kahn
    Eric Kahn Guest
    Bump
    does the guality of the rear speakers make that much difference???
  3. Scott O'Keeffe
    Scott O'Keeffe Stunt Coordinator
    Jun 1, 1999
    77
    Hi Eric,
    I don't think they matter as much as your fronts as far as quality goes, but I definitely advise that you stay with Klipsch as you want to have some matching, that's for sure.
    I'm not too familiar with the Klipsch line, but I'm sure you can't go wrong with those Quintets.
    My .02
    Scott
