rear riser question
Discussion in 'Home Theater Projects' started by Travis, May 9, 2006.
  1. Travis
    Travis Second Unit
    Nov 17, 2003
    258
    I have just finished framing the rear stage and have a q before laying on the roofing felt and plywood. My front stage is filled with sand but I am wondering what to do with the rear. I have heard of filling it with R19 but am not sure how much. Does it need to be completely full or can I get away with just laying a roll along the bottom? The riser is 10" tall so I would prefer not to fill it to the top if it is not necessary.
    Travis
  2. chris_everett
    chris_everett Second Unit
    Jul 20, 2003
    403
    The more you have in there the better. Ideally, stuffing it with something like mineral fiber insulation (or even more sand) would be best.
  3. Travis
    Travis Second Unit
    Nov 17, 2003
    258
    Is it's purpose to cut down on the echo when you walk on it, or is there more to it?
    To clarify, I mentioned rear stage, but it is the rear riser. I'm sure you already figured that out.
  4. chris_everett
    Jul 20, 2003
    403
    There's more to it. If the platform is not dampened, it will vibrate at certain frequencies, screwing up the bass in your room. It can also make noise when that happens. Furthermore, the air inside it can vibrate as well at a paticuler frequency. In my riser I used the leftovers of mineral fiber insulation, and filled the rest with Fiberglass.
  5. Travis
    Travis Second Unit
    Nov 17, 2003
    258
    Thanks Chris,
    I will make sure it is sufficiently dampened.
  6. David Noll
    David Noll Stunt Coordinator
    Aug 31, 2004
    228
    Travis,
    My riser is two levels high. I stuffed mine with twice the regular amount of fiberglass insulation. No problems at all. Very quiet to walk on and no echo, boominess etc.
    David
  7. Travis
    Travis Second Unit
    Nov 17, 2003
    258
    I ended up picking up 2 rolls of R38 which should fill it nicely. Thanks for the replies.
    Beautiful theater by the way.
