Rear projection TV size and advice needed
Discussion in 'Archived Threads 2001-2004' started by Brian Bowles, Nov 3, 2002.
  1. Brian Bowles
    Brian Bowles Second Unit
    Dec 3, 2001
    256
    I was looking at rear projection televisions the other day at Best Buy. The guy there recommended the Mitusbishi over the Toshiba but said that both were good. What oppinons do you guys have on these and others.
    Also, the room this would go in is 20x18 with 12 foot ceilings. It will be going on a very large wall and our couch is about 11-12 feet from the front of our current console that has a 27 inch television in it. Is a 65" television too big? What size do you recommend? Thanks so much for your time and oppinions.
  2. Justin Gates
    Justin Gates Agent
    Feb 26, 2001
    47
    IMHO, 65" is perfect for a veiwing distance of 10 to 12 feet. But the choice is really up to you and your preferences. Go view one on display at that distance. Just remember when you first get a much larger television than what you currently own, it will appear mammoth. Then as you get used to watching it, it wont feel as large. I sit 8' from my 51" and am now wishing I went with the 57".
  3. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    I agree with the 'shrinking' phenomenon. I sit 10 feet from a 60-inch, and wouldn't want anything smaller. The 60-inch seemed so large in the store, but once you're accustomed to it, it 'shrinks'.
  4. DavidAM
    DavidAM Second Unit
    Sep 30, 2001
    375
    I'm 7 feet from my 56" and it was big at first, but I wouldn't want it any smaller now. I'd go with the 65".
