Rear panel for Omnimount
Discussion in 'Speakers' started by jason bergman, Jan 5, 2005.
  1. jason bergman
    jason bergman Auditioning
    Oct 31, 2004
    3
    Hi all,
    I'm moving, and when I do, I'm going to need to get Omnimount brackets for my Energy E:XL-R.
    I already know which one I need to get, the only thing is I think I need a rear faceplate for my speakers, and I don't have one. Where can I buy one? Is there some place I can go to that will have both the mount and plate?
    Ideally I'd just call this place, tell them my speaker model, and get what I'd need.
    Any help steering me in the right direction is much appreciated.
    Thanks!
  2. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    Does your Energy speakers come with predrilled holes or predrilled screws for mounting brackets?
    My Phase Tech's did and the brackets I bought did NOT come with the rear faceplate.
    You may need to drill your own holes. If that is the case, I'd call Energy.
  3. jason bergman
    Oct 31, 2004
    3
    It has holes that I assumed were for a faceplate...maybe the omnimount goes directly into there?
    I'll give Energy a call.
    Thanks!
  4. Shane Martin
    Sep 26, 1999
    6,017
    Jason,
    Most likely they do. Mine had predrilled screws. I just mounted the plate that comes with the package(I bought the OM10's Ceiling version) and it bolted right up. Easy as pie.
