Brad Russell
- Aug 13, 2003
I've decided to move the 1985 era Infinity RS5bs (10" 3-way) from my rear surrounds to my living room upstairs to just to two channel duty. So my question is do I replace the rears or do I move the Polk RT7's that I have been using in a dual center set up to the rear. My current set up is Yamaha A-1, Polk RT55s(mains), Polk RT7's (dual centers, one on the floor angled up and one on top of my 32" TV slightly angled down. There is about 4' between them and the A-1 has two sets of binding posts for dual center set up), Polk RT15is (front effects, Yamaha DSP) and a PSB subsonicIII sub. Room is approx. 2700 cu/ft
I'm planning on going to a front projection TV when the funds become available, as well as one or two SVS PB2-isds.
Over at the Polk forum a number of people are creating "super centers" by combining multiple centers or book shelf speakers into one long horizontal speaker.
http://clubpolk.polkaudio.com/showca...c=6_25_big.jpg
Right now I can get a pair of Polk RT38is for 200 a pair.
or a CS40i for 300. So I'm wondering if I get the 38s and just use them as rears or do I move the RT7s to the rear and get either a CS40i? or go dual center again with a pair of 38s? Or should I try to find an older CS400 to match with the 55s? I'm a little confused that Polk has removed the front bezel on the CS40i that the 400 had and wondering if that will cause a mismatch with the 55s that have the bezel.
If anyone has made it through this post and can offer a suggestion I'd sure appreciated it!
Thanks!
Brad
Thanks!
Brad
