Rear Center on 5.1
Discussion in 'Archived Threads 2001-2004' started by Mark Starratt, Oct 5, 2002.
  1. Mark Starratt
    Feb 26, 2002
    35
    I seem to recall reading that you can wire a centre channel speaker for a quasi 6.1 effect on a 5.1 system. Anyone know if this is true? How do you wire that?
  2. Geno
    Geno Supporting Actor
    Oct 1, 2001
    637
    yes you can, but im sot sure how it will affect your amp/receiver.
    wire the center rear with the positive leads from your
    l/r rears. this will basically play both signals thru one speaker
  3. Stasulos
    Stasulos Stunt Coordinator
    Sep 9, 2002
    50
  4. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    No! By doing this you will be getting the OUT-OF-PHASE info from the 5.1 surrounds. EX/ES rear center is the MONO IN-PHASE info from the 5.1 surrounds as well as removing the Mono In-Phase info from the Surround L/R. What you need is a Dolby Prologic receiver's front channel decoding to run the three surround channels or a EX/ES receiver.
    Wes
  5. Will Orth
    Will Orth Stunt Coordinator
    Sep 14, 2002
    80
    i have a rear center out on my sony but cant use it as my room is not deep enough :[​IMG]
    Will
  6. Geno
    Oct 1, 2001
    637
    Stasulos - to ge the desired effect [from what I suggested], you must use both positive feeds. Ive used this method for a single outside speaker.
    Wes - So they would need a DLP decoder for just the rears then they could theoretically accomplish this feat?
    Will - ...huh?
  7. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
