Ready for a silly question about speakers? Get ready...
Discussion in 'Speakers' started by James USAF, Oct 10, 2003.
  1. James USAF
    James USAF Agent
    Jun 21, 2003
    32
    what is the best way to clean the grill mesh? :b
  2. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    If you're talking about cloth grilles, I've had good results with spray-can foamy upholstery cleaner. Take the grille off first, support the backside with a clean towel, spray on the foam and gently rub clean with another clean rag or towel.
    For perforated metal grilles or something like that... I suppose just take them off and scrub them with a brush and soapy water.
  3. Dan D Burke
    Dan D Burke Agent
    Feb 16, 2003
    36
    That's not a silly question at all.
    Dave, out of curiosity, what brand of cleaner do you use?
  4. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
    I use the "wand" of my vacuum cleaner without any attachments. If that makes any sense.:b
  5. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    If you are a real man and have a air compressor, that migth be a good place to start.
  6. Aaron Gilbert
    Aaron Gilbert Second Unit
    Sep 17, 2003
    319
    Well, I don't have grills on any of my speakers at home, but at work I use high pressure air, or the aforementioned cloth and some windex for metail grilles.
    Aaron Gilbert
  7. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
