Re-insalling XP to C: drive; will my D: hard drive be unchanged?
Discussion in 'Computers' started by Timon Russo, Jul 16, 2004.
  1. Timon Russo
    Timon Russo Stunt Coordinator
    May 10, 2000
    213
    I figured I could just back everything up to there, and have it be intact at the time the re-installation is complete. Is this right, or am I in for a rude awakening?
  2. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    I'm guessing it's a seperate physical drive and not a partition?
    You'll be fine if so. When you do your format you'll be able to choose which drive to format and again with you install Windows. Just make sure you choose C:
  3. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    If you reinstall windows without a reformat, all the non-windows information on your C: drive will be left alone as well. Windows installation will only delete the C:windows or C:winnt folder.
  4. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    if you have data in the 'my documents' folder, i'd move that somewhere else. i'm not sure, but i remember hearing something about that folder being over-written during a windows reinstall.
    CJ
  5. Tekara
    Jan 8, 2003
    783
    Windows will make a new folder for whatever profile you make in the "Documents ane Settings" folder so all the information kept on there will be safe as well.
  6. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    Timon,
    You will, of course, have to re-install all your applications after re-installing Windows. Backing up apps to another drive won't serve any purpose.
  7. Timon Russo
    May 10, 2000
    213
    Thanks guys. I plan on doing it this week. Of course, I will be reinstalling apps. And this isn't a "repair" installation, I plan on formatting C: and starting fresh.
