Matt*B
- Apr 19, 2004
Hey all,
I am renovating my current “theater.” Right now. The room is lit by 3 fluorescent bulb units (you know, the 4 foot kind) behind a wooden frame covered with plastic lens. These are evenly spaced over the entire ceiling. The frames are about 12” x 50” What I plan on doing soon, is taking the frame/lens off, and removing the fluorescent fixture. Now, instead of the wooden frame, I am going to have a solid piece of finished wood in it’s place. In that wood frame will be two evenly spaced and centered recessed can fixtures with baffling to finish it off. This way I can have the “theater-like” recessed lighting with a nice finished look, and the option to put a dimmer on them… I am sure it will look great… I hope this explained it enough. Has anyone done anything similar to this? Any suggestions, hints?
Matt
Matt
