Rcvr (HK 7200) won't turn on???
Discussion in 'AV Receivers' started by Allan, Sep 5, 2005.
  1. Allan
    Allan Stunt Coordinator
    Oct 1, 2000
    205
    Hi all,
    I have had the Harman Kardon 7200 for about 1.5 years now and been very happy. Yesterday, however, the recevier stopped working. specifically, it will not turn on. I unplugged it, waited a bit, and plugged it in again and still nothing. I tried several outlets (which I know work) and still nothing. Any suggestion????
    thanks,
    Allan
  2. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    Could be the fuse. Check the back to see if you have one of those screw terminals for your fuse.
  3. Allan
    Oct 1, 2000
    205
    I was thinking it could be a fuse problem. Could you explain how to check it and how to fix it?
    thanks!
  4. Paul Mor
    Paul Mor Stunt Coordinator
    Aug 3, 2004
    82
    This will come as bad news, but I had the same thing happen to mine and it couldn't be repaired. I bought the extended warranty that most people think you shouldn't buy and I now have a new AVR 7300 after some debate. I had a loaner from Fry's for 3 months before they finally decided the receiver couldn't be repaired (but that's another story). You might try to contact H/K customer service. I believe their receivers have a 2 year warranty and I hear H/K customer service is pretty good.
    Good Luck
  5. Allan
    Oct 1, 2000
    205
    Paul,
    My rcvr is still under the 2 year warranty, and I actually bought an extended warranty as well. (so, I am not worried about coverage.) Being that I am in the 2 year warranty period, would you recommend that I contact HK directly or the store that I bought it at?
    thanks
  6. Paul Mor
    Aug 3, 2004
    82
    I took mine back to the store I bought it at, mainly for convenience. Not sure if that is the best thing to do, but I was able to get a loaner while they tried to repair mine and I didn't have to worry about shipping the unit, etc. That being said, I did waited over three months before they finally gave me a new one...H/K might be a little faster than that. I hope you get it repaired or replaced soon. Keep us posted on your repair experience.
  7. Allan
    Oct 1, 2000
    205
    Thanks. Update - Called the store I bought it at (Onecall) and they said to just bring it in to an authorized HK repair center. So, I am planning on doing just that....
  8. Allan
    Oct 1, 2000
    205
    Finally had time to bring the 7200 into the store this past Friday (Sept. 23). They said they will call me with an update in 5-7 business days....
  9. John S
    John S Producer
    Nov 4, 2003
    5,460
    This is a piece I am considering buying. Keep us posted please.
