RCA TV - Can't Find Remote
Discussion in 'Accessories, Cables, and Remotes' started by McKinley, Dec 20, 2003.
  1. McKinley
    McKinley Auditioning
    Dec 20, 2003
    6
    I have a 27" RCA TV in my bedroom. It's several years old. The remote control that came with it is starting to have problems, some buttons don't seem to work anymore. Anyway, I bought an RCA universal remote to replace it but there is a problem. The original remote that came with the TV has some features that the universal can't seem to mimic.
    I never programmed the universal, so is it possible that I have to actually enter a code for the RCA remote to operate my RCA TV?
    If the above does not solve my problem, can I possibly get another one of the original remotes from the manufacturer (or somewhere else)?
    --McKinley
  2. Johnny Ayala
    Johnny Ayala Stunt Coordinator
    Nov 13, 2003
    183
    You should try programing it first of all. If that doesn't work you can either get a "Kameloen" remote from Best Buy which does everything the original did ( in my case it did) or you can contact the manufacturer and get a replacment if they are still available. Good Luck. [​IMG][​IMG]
