Chris Brock
- Sep 13, 2003
i did a search on the topic and it seems like this will work ok, but I would like to have assurance that it would be ok. I plan to use this adapter from RCA to 1/4".....
http://www.partsexpress.com/pe/showd..._ID=2427&DID=7
then use this adapter to go from 1/4" to XLR.....
http://www.partsexpress.com/pe/showd..._ID=2504&DID=7
the male XLR connector would be plugged into my amp. Will this work ok or will i need some type of special converter to truly make it work properly? thanks!!
