RCA to stereo miniplug converter
Discussion in 'Archived Threads 2001-2004' started by Steve_Ch, Aug 23, 2002.
  1. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
    Is there such a thing ??? Tried the usual places, Fry's, CC, BB but no luck.
    Here is the deal: I have a stack of VHS tapes that I want to archive on CDR (VCD). I have a 20 year old Magnavox that's not being used and perfect for the job. The problem is my sound card takes a stereo mini plug for line in, the old Magavox is a mono and only has a single RCA audio out, so far, I have no luck finding a setup that has a single RCA to a stereo miniplug. I tried just plugged in one side of a 2 RCA to miniplug connector, but then I only get audio on one speaker.
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Yeah it exists.. check out like radioshack, they should have it...
    keep looking, it definitely exists
  3. Steve_Ch
    Oct 14, 2001
    978
    How can I forget Radio Shack !!! Will check, thanks.
  4. Chris Huereca
    Chris Huereca Auditioning
    Jun 27, 2002
    8
  5. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Ohyeah, if you cant do that, try just getting a splitter, but use it backwards.. i know its not the best way, but it should work.
  6. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    Steve, you can also just get a RCA Y cable and run your mono out on your vcr to two RCA cables and then at the other end run them into a stereo RCA -> mini converter. This won't get you stereo but it'll get the same signal out both channels. Wow, your vcr is 20 years old!? I had a Quasar from 1985 that lasted about 15 years - most of those in actual use.
    cheers,
    --tom
  7. Steve_Ch
    Oct 14, 2001
    978
    Thanks to all, the winner is Radioshack, they have a wall of gizmo connectors and convertor, one of which is a "phono to stereo minijack", BINGO ($2.99).
