RCA to headphone jack sound quality??
Discussion in 'Home Theater Projects' started by Mike Milillo, Apr 21, 2004.
  1. Mike Milillo
    Mike Milillo Stunt Coordinator
    Apr 14, 2003
    142
    Hey guys, would there be a difference in sound quality between using an RCA/RCA left/right audio cable as oppossed to an RCA/Mini type cable. I mean the cable that has RCA's on one side and a headphone type jack on the other end. This is in regards to a sirius plug and play unit. I am trying to compare a kenwood unit that has standard RCA jacks and an audiovox plug and play that accesses RCA jacks through a headphone type connector. thanks guys
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Hi Mike.
    Under "Ideal" conditions, either connection should sound the same.
    The problem is the real-world is not ideal.
    Full RCA jacks are superior because:
    - The interconnects can use shielded coaxial cable. (The 1/8" cables are often un-shielded wires)
    - RCA's have larger connecting surface with tighter friction-fitting connections.
    - The 1/8" cables are prone to shorts/breakage as the wires come out of the plug. (Ever have some headphones that cut-out unless you held the wire in a particular position).
    So I would give the nod to the Kenwood unit with real RCA jacks.
