IlyaG
- Sep 10, 2003
I am looking for a TV for my new place. I recently went and saw a used RCA F38310 38 Inch High Definition Direct View TV. The person that was selling it had HD broadcast hooked up and it looked pretty damn good, although i did see some artifacts(owner attributed that to being far away from HD source). The set was bought in July 2000 and looked to be in pretty good shape. He is asking $900 for the set+stand(no ext waranty). I might be able to bring him down to +/- $800, is this a good deal? If not, how much is? i ve read some reviews of the set and many people seem to have some major issues with it. I ve listened to the fan noise and it did not bother me much. I also tested the DVD there Moulin Rouge, and was not all impressed with the quality, it seemed like it was a little grainy at times.. but i think it might have beeen dvd's fault, or was it his dvd player? he said it was prog scan.
I am located in central San Jose, CA. Anyone have any idea regarding the quality of the HD signal i can get using a table top antena?
Any known issues i should look for before i buy the set? any known problems that i can check for?
how do i check what the version of the TV is? I head there where several versions and the later ones had less problems.
Any info would be appreciated, thanks in advance...
