RCA DTC100 Max Res 540 ?
Discussion in 'Archived Threads 2001-2004' started by MitchC, Sep 8, 2002.
  1. MitchC
    MitchC Auditioning
    Feb 17, 2001
    11
    Hi,
    I recently read that the RCA DTC100 HD receiver will allow a max display of 540 ? and not the full 1080 in a HD system with the oval Direct TV dish, HD ready Sony XBR TV and the RCA VGA/Comp converter. Can anyboby tell me the truth about this setup it seems the manufacturers don't give you all the details.
  2. Evan Hartnett
    Evan Hartnett Stunt Coordinator
    Jan 9, 2002
    118
    I'm really just guessing (I'm just learning about HDTV stuff myself) but isn't 1080i really made up of 540 lines?
  3. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi Mitch,
    The dtc does HD in 1080i. It upconverts 480i to 540p.
    I've had the dtc for about 3 yrs now and it works great.
    Seeing the Gator/Cane game and the US Open this weekend in HD was fantastic.
    Errol
  4. MitchC
    MitchC Auditioning
    Feb 17, 2001
    11
    Thanks for the positive response Errol, did you need to use the VGA/Comp converter with your TV ? and if yes does it work well ?
    Mitch
  5. errol
    Dec 29, 1999
    150
    Hi Mith,
    Yes, I use the Audio Authority transcoder. It is plug and play. Works great with the Tosh. I've also tested the Key Digital but it didn't work as well (i.e., synch problems).
    I use an AA for for the DTC-100 and and another AA for the htpc.
    Errol
